ejmorgan
Dec 18, 2025Explorer
Make sure the Propane Regulator is adjusted for proper gas pressure. The generator uses lots of propane. If the furnace, stove, and/or water heater are running, the generator may be "starved" for fuel if the gas pressure is too low. You may also need to replace the standard propane regulator with a "high-flow" model.
Having RV issues? Connect with others who have been in your shoes.24,412 PostsLatest Activity: Sep 13, 2026
