MrWizard
Nov 13, 2016Moderator
you said it got hot
it has NO business getting hot IF it is the charge relay which is suppose to be continuous duty
IF its getting hot, it will eventually fail
of course the normal voltages would be in the 13~14v range
NOT 16v+ equalizing voltage
that relay should not be getting 16+ volts on its coil
if you are doing that, it will fail sometime
Having RV issues? Connect with others who have been in your shoes.24,380 PostsLatest Activity: Apr 16, 2026
