MrWizard
Nov 20, 2016Moderator
The problem I see now
Is your procedure
Iirc batteries are supposed to be fully charged normally (what ever number of hours it takes to get them there)
Then you check sg, then you equalize them , checking sg until they are as close to oem as possible
You don't start the equalize voltage from a partial SOC
Equalize is not a charge cycle
You don't do it, unless the batteries are already fully charged
Is your procedure
Having RV issues? Connect with others who have been in your shoes.24,386 PostsLatest Activity: Nov 08, 2021
