Huntindog
Feb 25, 2014Explorer
Bobbo wrote:It absolutely can be condensation. Read the OP again. If you have ever used your TT in freezing weather for any length of time, you will need to take steps to minimize condensation. The OP is doing everything wrong in this regard.
I'll agree. Enough water to make the carpet wet is not condensation.
I, also, had a loose air conditioner. I tightened the bolts holding it down to compress the gasket about 1/4 inch and my leaks stopped.
Of course there Could be another leak, but it's not likely as the tempertures are so cold as to freeze the vent covers shut.
Ice doesn't leak.
Having RV issues? Connect with others who have been in your shoes.24,412 PostsLatest Activity: Sep 13, 2026
