BobsYourUncle
Feb 27, 2014Nomad
Huntindog wrote:BobsYourUncle wrote:Do you have AC hook ups at all?
Well, I would open some holes up and get the air flowing, but when it is so cold out, it is hard to do.
Open a window or roof vent and in 20 minutes it has dropped ten degrees in here and the furnace runs full tilt!
I know I need ventilation, I know I need a window and vent open, but I just can't. It's hard enough to keep the place warm.
Now if I had 3 shore power hookups like PianoTuna then I wouldn't be so concerned about a little heat loss!!
If so get a dehumidifier. I use one, and it works great. I can close the TT up tight, and the dehumidifier actually kicks out a little extra heat while it is doing it's primary job... Of course it may be a little late for it now. The damage is likely already done.
I have one 15A circuit only to run everything. I'm lucky it is a strong one. 1500W heater, a heat tape and my converter all running off the circuit. Haven't tripped it yet.
Supposed to drop to -33C (-27F) tomorrow. Should be interesting....
Having RV issues? Connect with others who have been in your shoes.24,412 PostsLatest Activity: Sep 13, 2026
