RVER wrote:
Down home These all sound expensive but will have to get whatever is needed done so we are safe.
I need to have the brakes checked some how they do not seem to work by pressing the brake pedal but when I use the lever on the bottom of the Prodigy the brakes work so could it be corrosion on the plug. The indicator does show it is connected when I plug her into the outlet on my truck but the brakes are not getting the message.
I'm not good enough to figure it out from here.
......Might the controller internally. Check all the connections.
Somebody here has tore into one?
