NRALIFR
May 28, 2021Explorer
Fisherman wrote:
I've stared at that last picture where you disassembled the pump for 5 minutes to see what is wrong but what is wrong?
Sorry, I should have circled that. :)
The item I’ve circled in the image below I believe is a check-valve that prevents the water in the pressure side of the pump from bleeding back into the suction side. Two of the little plastic legs of the cage supporting the rubber diaphragm are broken, and a bit of the rubber is poking through. With the shutoff valve closed, there’s very little water line left to hold pressure, so it bleeds down quickly making the pump cycle faster.
Having RV issues? Connect with others who have been in your shoes.24,390 PostsLatest Activity: Jun 05, 2026
