Wayne Dohnal wrote:
gotsmart wrote:
....has anyone come up with a solution to this, either at the genset or PD converter?
I'd call this a workaround. If you run a nice big resistive load like the water heater or a space heater, the Onan Microquiet's waveform will improve and the PD's output will increase. Still not as good as with an inverter generator, and you'll burn a bunch more fuel.
Seems similar in a way to the suggestion in my Vector MSW 2000w inverter's manual:
Trouble: Motorized power tool does not operate at correct speed
Possible Cause: Purely inductive load
Suggested Remedy: Make the load not purely inductive. Operate an incandescent lamp at the same time as motor
