DrewE
Jul 30, 2015Explorer III
WyoTraveler wrote:
I don't think the torque on the nut or bolt changes. i.e. mine clicks at the same torque. The advantage of an extension would be that I would need to apply less effort on the handle. Those 350 lb torques get harder as I get older. The longer handle helps.
I believe they're talking about extensions between the ratchet head and the socket, not extension ("cheater") handles. An extension handle shouldn't affect the accuracy of a torque wrench provided it's applying the force similarly to the torque wrench as usual manual operation would and not otherwise interfering with the mechanism...and naturally a handle extension does increase your leverage.
A socket extension also shouldn't affect the torque enough to possibly care about, as others have mentioned, when using a hand torque wrench.
Having RV issues? Connect with others who have been in your shoes.24,410 PostsLatest Activity: Aug 30, 2026
