MR_MAC's avatar
MR_MAC
n Dometc AC cycle problems
2014 Coachmen Persuit, AC unit driving me nuts. sometimes will run for a hour or more then will stop for two min. on for five min. over and over again some times it w ill run right up to set temp. stop and will not start unless I( shut it off and restart. A few times when short cycling the thermostat will show a E5 code. Now its at dealer for two wks. and they say nothing wrong. There is something wrong I spent two wks in Tenn. at 90 deg. with no cool.
  • Don't worry by now dealer has found problem :S
    It amazes me....appliances (A/C Units/Thermostats/Refrigerators/Furnaces/Generators) give Error Codes/Fault Codes and nobody takes the time to look at the 'chart'
    Dometic T-stat
    Error Code:
    E1 Loss of communication between the CCC 2 thermostat and all system power module boards. System will shut down.
    E1 Loss of communication between the CCC 2 thermostat and an individual system power module board. The LED will display error code EI and the zone number that lost communication. Any additional zones that loose communication will blink in addition to the current zone.
    E2 Open circuit or out-of-range indoor temperature sensor. All heat , cool, and de-humidify operations will be locked out. Manual fan operation will continue.
    E3 Shorted Indoor Temperature Sensor. All heat, cool, and dehumidify operation will be locked out. Manual fan operation will continue.
    E4 Open circuit or out of range Outdoor Temperature Sensor (select models). Heat pump and dehumidification operation will be locked out. Air conditioner, furnace, heat strip and fan operation can continue to operate.
    E5 Open circuit or out of range Freeze Sensor. Air conditioner and dehumidification operation will be locked out. Heat pump, furnace, heat strip and fan operation can continue to operate but displays the last temperature set-point.
    E6 Open circuit Humidity Sensor (Select Models). Air conditioner and dehumidification will be locked out. Heat pump, furnace heat strip and fan can continue to operate.
    E7 Loss of 120 VAC power to all power module boards on the system. The system
    will shut down.
    E8 Invalid zone configuration. The heat pump and heat strip DIP switches are both set to the ON position in one zone. Heat pump, heat strip, air conditioner, and dehumidify operation will be locked out in the affected zone.
    E9 Invalid zone configuration. The dehumidifier DIP switch and either the heat pump or heat strip DIP switches are set to the ON position in one zone. Heat pump, heat strip, air conditioner, and dehumidify operation will be locked out in the affected zone.
Having RV issues? Connect with others who have been in your shoes.24,392 PostsLatest Activity: Jun 09, 2026
