- wa8yxmExplorer IIIThere are really only a few things that can go wrong on an RV Absorption fridge.
Burner dirty/clogged. Routine burner cleaning (An insect loves to nest in gas lines)
Spark gap too wide (never seen it on a Fridge but several other devices)
Bad control board gas valve or propane supply
Bad electric heat element
Tripped thermal breaker (yes there is one look on the "Stack" (right side outside) for a small white button)
Failure of cooling unit
The breaker you push button
The Spark gap you reset per instruction manual
The burner oriface you clean
Blast some air (not too powerful) DOWN from the top to blow crud off the heat exchanger.
Propane supply you refill the tank or replace the regulator or both.
The rest you replace the module. - If connecting the element direct to test, leave it connected for 24 hours and see if refer cools correctly. You replaced the Board. Did you use Dometic or Dino? The refer works on LP correctly? Doug
You have posted 4 times on this thread. NOT ONCE have you stated the Model and year of Refer. AND, your last post seems to indicate the refer operates and cools correctly? Just not on 120 volt? - tom01hanksExplorerIn Dubai especially during the hot summer season, It is always essential to protect your air conditioning and refrigerator system to avoid unnecessary breakdown. If anyone experiences cooling issues at home and looking for immediate AC and refrigerator maintenance & service from a highly qualified, professional company then call ***Link Removed***.
- kahoonaExplorer II
wa8yxm wrote:
The Dometic Absorption Fridge (And the norcold) for the most part there are only 4 or 5 repairs I will list them
Dirty fins (Had that but not totaled) blow air DOWN from the top to clean if you can't get to 'em any other way.. NOTE External fans cause this (Per my Technician)
2: Burner maintenance... Described in many manuals including the one Dometic prints.
3: Electric heat element replacement.
4: Electronic issue (Control board, includes blown fuse and bad wiring)
5: OUCH: Cooling unit failure (JUST put in a new cooling unit) Have that done by a pro. Two reasons. one is warranty on the cooling unit (If you put it in yourself 100% they will say "Bad install") 2: Well I've assisted said pro and I still don't want to do it.
Fins good
Done the burner, boiler and stack maintenance
Element resistance checked and good and I am actually testing it by connecting directly to AC and it works. Does not work through board.
Fuses on board good and board is new. - Jay_PatExplorer
jkwilson wrote:
Watch the videos on RV Refrigeration you’ll know as much as a typical tech.
I agree!
Pat - wa8yxmExplorer IIIThe Dometic Absorption Fridge (And the norcold) for the most part there are only 4 or 5 repairs I will list them
5: OUCH: Cooling unit failure (JUST put in a new cooling unit) Have that done by a pro. Two reasons. one is warranty on the cooling unit (If you put it in yourself 100% they will say "Bad install") 2: Well I've assisted said pro and I still don't want to do it. - kahoonaExplorer II
I have to say that that guy actually knows what he is talking about!If you look at the vid on Bypassing the board that is exactly what I did the day before. It took me a week to figure out that I could. Recommended reading for sure and If I ever get up that way I'll pay him to fix it! Thanks - kahoonaExplorer II
Thanks. Will do now. - jkwilsonExplorer IIIWatch the videos on RV Refrigeration you’ll know as much as a typical tech.
Having RV issues? Connect with others who have been in your shoes.24,369 PostsLatest Activity: Jan 12, 2018
