mchero's avatar
mchero
Need a new tank for my Atwood G16-EXT
Anybody know of good prices on just the tank?
Thanks
  • mchero wrote:
    Need both gas/electric.
    Thanks for the link.
    Then that would be an Atwood 91060 for replacement tank
    *Model would be GE16-EXT (not G16-EXT as you originally posted)
  • If the round tube ends that the flame goes thru are not PERFECTLY round, do not accept.
    Been there done that, and it ain't pretty.
  • Aluminum tanks corrode from the inside out. Found a pin hole leak on a aluminum sleeve that the fittings are threaded into. Was able to seal but expect more to show up down the road.
    Found a tank for $99 but the wonderful USPS lost the package!
  • Since you just want a tank, what's the problem with the old tank? I had one freeze and split. I had it welded back together, and it worked great.
  • Atwood G16-EXT
    Gas only/10 gallon tank using a Mixing valve to provide 16 gal of HOT water
    Replacement tank is same used for all gas only 10 gal models--- 93950
    Best price is probably Panther RV
    IF available!
Having RV issues? Connect with others who have been in your shoes.24,396 PostsLatest Activity: Jun 24, 2026
