klutchdust
Oct 20, 2014Explorer II
donn0128 wrote:
As I see it you have a couple of options. Genie and a slave for the second TV or get serious and rewire the RV in the right way. I just did a serious modification in my fiver so I can run a genie and wireless slave off on two different dishes.
Rewire the Rv the right way, meaning what? Im tired of adding additional boxes, wires ,cables, plugging in things then unplugging something else. The front of my coach looks like a control panel for a DC-10 and I still
don't have Tv in the bedroom. Had to unplug something this morning to grind my coffee, lost my signal then had to reboot. PITA. I get up at night and there are enough red lights on to light my path.
Running an additional cable from the satellite to the front of the coach, that looks like fun. Do they run those cables through tubes or spray insulation on them so you have to remove roof panels. My friends call on me when
the job requires patience so I can run a cable from anywhere if I have to .
Having RV issues? Connect with others who have been in your shoes.24,369 PostsLatest Activity: Mar 09, 2026
