dougrainer
Oct 21, 2014Nomad
klutchdust wrote:dougrainer wrote:
Since you have a single LNB Dish and that means you CANNOT get Direct HD channels, get a older Direct TV receiver(non HD) that has coax out to TV. Then just use the RV's coax cable to power each TV. Since NO HD , there is no reason to use HDMI cables. Doug
I contacted Direct and they do not have a receiver with the coax outputs. All of theirs have the HDMI outputs and the coax inputs.
You purchase an older receiver on E bay that has the coax. If the Direct receiver has the Yellow/Red/White RCA output, then do this-
http://www.amazon.com/Philips-SWS2103W-17-Discontinued-Manufacturer/dp/B001UYUNSE
Having RV issues? Connect with others who have been in your shoes.24,369 PostsLatest Activity: Mar 09, 2026
