KATOOM's avatar
KATOOM
Need a quick answer from the battery guru's
I thought I remember this being talked about, but knowing that the battery chargers in the RV/trailer tends not to deliver enough amps to bring the batteries up from a low charge (say like overnight usage) when just firing up the generator. So it was advised to get a separate battery charger and use that to charge the batteries instead. So with that said, my question is, how many amps and for how long is it normally required to bring the batteries up to a decent charge? I thought there was a formula for battery size per amps per hour, or something like that. I know that was just asked in layman's terminology so bear with me. Also, the charger I have is a 6 amp / 2 amp charger. Thanks.
Having RV issues? Connect with others who have been in your shoes.24,369 PostsLatest Activity: Mar 15, 2026
