Golden_HVAC
May 27, 2016Explorer
So you have a 2" receiver on your motorhome? How high is that from the ground when parked on level ground?
I think that you will want the ball to be close to 18" off the ground. So if your receiver is 18" above the ground, then a straight hitch will work fine. If it is at 22" above the ground, then a 4" drop. If only 16" - then a straight hitch will still work fine.
You can pick them up at many Wal Marts, your local hardware store, and many other places. If you have a exceptionally high hitch, such as 24" or 28" above ground level, you can buy a receiver with up to 10" or 12" of drop. That you probably have to order from ETrailer.com
I put a hitch on my Windstar van when I was towing it so that I could move the tow dolly around, and to go and purchase the dolly and bring it home, without towing it with the RV.
Good luck!
Fred.
Good luck!
Fred.
Having RV issues? Connect with others who have been in your shoes.24,370 PostsLatest Activity: Mar 18, 2026
