donn0128
Mar 17, 2014Explorer II
I assume you have hard water at home? If so give your home filter company a call and ask them about a portable system you could use. Either that or consider filling your water tank from home.
Anode rod is a sacrificial part that should be replaced each year or so. Not sure how anyone can remove calcium deposits from water lines? I suspect you got $530 dollars for replacing the anode rod ( 10 dollar part, five minutes labor) and fixing the door lock. It is time you learn to do repairs yourself or your going to continue paying 100 dollars an hour labor for piddly little things.
Having RV issues? Connect with others who have been in your shoes.24,363 PostsLatest Activity: Mar 04, 2026
