MEXICOWANDERER
Nov 10, 2017Explorer
- With memory card for stand alone operation.
- and internal cold junction compensation for thermocouples.
USB PC-logger module for thermocouples, RTD's
Thermistors, semiconductor sensors and similar analog sensors
Special Features
- Logger can also be used as a temperature controller and temperature control.
- No external power supply needed
- Extremely high resolution of only 0,000005V (0.5uV)
- Due to the very high resolution sensors can be connected with very little external circuitry.
- Linearization of 15 of the most common sensors are integrated in accordance with DIN. Simply select the sensor.
- No full-bridge circuit or expensive measuring amplifier required.
- Optional galvanic isolation from the PC to 500V / 2500V, (data and -power) please ask if required.
- Plug & Play compatible
General
Logger has 8 variable digital I O's. At the same time to 8 digital I O's can be connected to the logger to 16 sensors.
Each of the 16 analogue and 8 digital channels operates independently.
Long term measurements up to 10,000,000 samples channel are carried out.
The cycle time of each channel can be determined individually.
Formula: Cycle time s = 0.5 s * number of activated channels.
The recorded values ??are stored in an ASCII file (text file).
So an export to external programs is easily possible.
Each measured value is stored with date and time.
Furthermore, a separate file is created for each channel.
Possible fields of application:
- 16-channel PC-multimeter
- 16-channel PC-Data Logger
- 16-channel PC logic analyzer
- 16-channel PC power failure display
- 16-channel PC power failure display (resistor required)
usw.
it can also be external sensors can be connected.
for example:
- Analog temperature sensors
- Analog pressure sensors
- Analog moisture sensors
- Analog brightness sensors
usw.
Scope of supply:
- Description
- 16-channel 23-bit data logger (LE-LOG_1623_USB_TE_SP)
- Original Software (Full Version, english version)
Cable: USB
Tested operating systems: Windows XP or later
Special Features
General
usw.
for example:
usw.
Scope of supply:
- Description
Cable: USB
Having RV issues? Connect with others who have been in your shoes.24,373 PostsLatest Activity: Apr 04, 2026
