PapPappy
Jan 26, 2014Explorer
You may be able to put a "tee" where the vacuum breaker is, but turn it 90-degrees, towards the wall, then a piece across the bottom, and then an elbow up at the wall with vacuum breaker moved.
There may be enough room, depending on the tub, and how it sets from the wall.
You just want to have that vacuum breaker in place somewhere above the drain.
Having RV issues? Connect with others who have been in your shoes.24,394 PostsLatest Activity: Jan 17, 2025
