time2roll
Sep 24, 2013Nomad
If you are measuring direct on the actual battery post you probably have a bad battery. It would take 150+ amps to drop a good battery to 10 volts that fast.
Otherwise I suspect a bad connection somewhere is causing voltage drop.
Having RV issues? Connect with others who have been in your shoes.24,397 PostsLatest Activity: Jan 16, 2025
