dougrainer
Sep 16, 2020Nomad
Class A makers do NOT run the items thru the Ignition switch. They install a separate solenoid that IS powered by the Ignition switch to power hi draw and extra appliances. Especially the ones you mentioned, which almost all use that separate Solenoid. The fact they were intermitant then failed shows it is this extra solenoid. IT IS NOT FRTLINER INSTALLED OR FRTLINER WIRING. It is the RV maker wiring. Doug
Having RV issues? Connect with others who have been in your shoes.24,410 PostsLatest Activity: Sep 03, 2026
