Old-Biscuit
Aug 07, 2017Explorer III
Do you torque your lug nuts?
How fast are you towing that would cause "too high a torque load when cornering to the outside at higher road speeds on I 81 in Pa and NY."?
Sorry ...I was only a Stationary Engineer
But lug studs shearing are due to Loose lug nuts OR stretched studs due to over torquing lugs.
Don't think changing wheel offset will be the cure.
Might affect wheel bearing thrust loads.
Having RV issues? Connect with others who have been in your shoes.24,409 PostsLatest Activity: Aug 29, 2026
