ScottG
Aug 07, 2017Nomad
If some shop over tightened the lugs, they will eventually break off as you describe.
When you put lugs on does the nut get tight in the middle of the threads, loosen and then tight again as they make contact with the wheel?
If so then the studs are stretched.
Having RV issues? Connect with others who have been in your shoes.24,409 PostsLatest Activity: Aug 29, 2026
