Roger10378
Aug 08, 2017Explorer II
How much offset are you talking about? If it is only a few mm there is no way it will make any difference. Even large offset(>20mm) mainly affect bearing loads not bolt loads. As said before broken studs are usually caused by either loose lugs or streched lugs from a previous over tight lugs.
Having RV issues? Connect with others who have been in your shoes.24,409 PostsLatest Activity: Aug 29, 2026
