hawkhill's avatar
hawkhill
Need GFCI location for Carriage Cameo F35SB3
My outside electric outlet is no longer working along with my bathroom outlet and my microwave. All breakers are good. The GFCI located in the kitchen is fine and working. I seem to remember this happened in the past and there is another GFCI located in the RV that needs to be reset, but for the life of me it cannot be located. Anyone have any idea where the GFCIs are located in a 2008 Carriage Cameo F35SB3?
  • It's the one your refrigerator is plugged into. Check behind the fridge.
  • Even if you find them all. GFI's can be just bad.
    If there is a light it will be on, even if you push the button in and out it will work BUT it will be defected.
    I've had to replace 2 that appeared ok but didn't work. I think its because GFI's in an RV get a real workout compared to a stick built.
    Who hasn't had to reset the gfi every time we forget and plug in the coffee maker and the kids fire up the hair dryer. I think they get over worked and fail more often.
  • The size of your rig will have at least 2 maybe 3 GFI outlets. They cover other outlets downstream. 3 or 4 outlets per circuit. GFI protected circuits cover all outlets within 6' of a water source, also ground level outlets and outlets inside ground level storage areas. They hide well.
  • GFCI are often place in "wet" location. Check the bath room and any outside outlets -- you may have more than one.
Having RV issues? Connect with others who have been in your shoes.24,394 PostsLatest Activity: Jun 15, 2026
