Tom_M1
Dec 06, 2019Explorer
If this is a permanent install you don't need connectors. Just wire direct from panel junction box to combiner box. Any connector will add a bit more resistance to your run. If connectors are needed, I would suggest using Anderson Powerpull SB50 connectors. The contacts can be crimped or soldered.
https://powerwerx.com/anderson-sb-connectors-sb50-50amp
