88flaminchevy
Nov 30, 2015Explorer
MrWizard wrote:
like wolfe said
its not about 240v
its all about having (2) 30amp 120v circuits from the generator to feed the RV that would normally have (2) 50amp circuits if using shore power, your gnerator is big for a 30amp transfer switch, you can't use all of the generator power, that switch is for (1) 30amp shore/generator feed
transfer switches have one output two inputs, the switch chooses which one is being used
you have a choice use only (1) generator circuit one hot & neutral
or get a 50 amp transfer switch, to switch both hots and the neutral
does the TT have a 30amp shore cord or a 50amp shore cord ?
or NO shore cord
The TT is a 50 amp transfer switch.
Having RV issues? Connect with others who have been in your shoes.24,343 PostsLatest Activity: Dec 11, 2025
