time2roll
Dec 01, 2015Nomad
The hots are known a L1 and L2 as in Line 1 and Line 2. So connect the generator to those terminals. The neutrals will go to Neutral and Aux that is jumpered to the Neutral. Ground to ground terminals.
Shore line (cord) and Load (RV) will be similar with just one neutral.
Is there an issue with this? I do assume you have a 50 amp RV with two main breakers.
The 15 amp 120v utility cord needs the hot to connect to both the hot connections in the transfer switch shown.
As far as powering everything with the inverter... that is a romantic gesture but most RVs can kill four batteries in less than an hour if everything is running. Not sure that is very effective. Best to describe the actual loads in your custom build for best results.
Having RV issues? Connect with others who have been in your shoes.24,343 PostsLatest Activity: Dec 13, 2025
