MrWizard
Dec 01, 2015Moderator
Quote from your info L1 and L2 are rated for 35 amps each
I don't care what the seller , Mfg, or distribute says
But 35 amp contacts will not carry 50 amps
So that is not a 50 amp switch
But yes you should be able to wire that to the Onan genset
But if you ever plug into 50 amp shore power which is connected to a double pole 50 amp circuit breaker, be careful to keep you loads down to 30 amps per leg
Having RV issues? Connect with others who have been in your shoes.24,343 PostsLatest Activity: Dec 13, 2025
