sscheitel's avatar
sscheitel
Need help choosing generator(s)
Jayco 32BHDS Jay Flight with 15k AC / 2nd AC with 50A service
can you please tell me what I need to be fully self sufficient?
Considering (2) Honda/B&S 3000 units or Q6500/EU7000iS
What are my best options? pros? cons?
Thanks
  • When I looked for my generators my criteria was;
    #1 MUST be the quietest out there
    Run the amps I need when I need it
    Be able to load in my PU by myself
    So I looked at the dB's
    The weight
    I ended up with (2) Honda 2000's. Nobody beats their dB ratings that I found.
    I went with (2) so I could lift them and I only run 1 unless I want the AC then I power up the other.
  • sscheitel wrote:
    How about this one folks?
    http://www.lifanpowerusa.com/inverter-generators/energy-storm-7000ier-efi/
    Great all but the weight and run time. So if you are going to mount it somewhere and can get more gas to it, it would work.
  • Going to go with two Champion 3500 with the parallel kit with 50A receptacle.
    I want to build a DIY extended run fuel system. I understand that it would be gravity fed and that careful attention would need to be paid when removing the fuel cap from the generator as the extended run system would keep the generators tanks full to the top.
    My question is where can I find the extended run gas cap for the Champion 3500?
    Champion Generator 100262
    PS For those interested HD has the pull start 3400 on sale for 799. Good deal if you don't want the wireless remote start
    Price?
  • Check with Supergen.com , they have an extended run system for the champion, with a pump operated from engine vacuum
    It does not have a lot of lift
    Generator and extended tank need to be nearly level
    Both on ground, truck bed, etc..
    But it's not gravity feed, no special cap
    Uses an add-on nipple for connecting the external tank fuel line
    Don't know how well that works with t the multi fuel system
    Whether or not there are any complications
    Best to ask them
    Best to ask them
    There is no Supergen.com. There is a SupergenProducts.com, but I can't find an extended run kit. Could you post a link? Thanks.
  • turbojimmy wrote:
    pianotuna wrote:
    turbojimmy,
    6000 watts per leg = 12000 watts total.
    I didn't realize that's how they calculated it. Just out of curiosity, is that the way residential current is measured? Is my "200 amp service" 200 amps per leg?
    In short, yes.
    The neutral wire "seems" to be too small, right?
    But when one phase is maxxing amperage, the other phase isn't.
    200 x 200 is 40,000 va. Not watts but it is equal to one large generator. Say 40 Kw prime power.
  • supergen extended run system
    round thing in the middle with hoses is the vacuum operated fuel pump
    mounted with rubber strap to protect from engine vibration
    there is nipple mounted top rear of generator for connecting the aux tank,
    my generator is on slide/tray in forward compartment
    to use aux tank i have to set it on a table level with generator
    so i have only used it a couple of times
    would work great with generator on the ground or in the bed of a PU truck, doesn't have the fuel lift to work consistently with MY SETUP with tank on ground and genny above it on the slide
    works well when both items are same level
    the Yellow Hose is the 'oil drain' for changing oil
Having RV issues? Connect with others who have been in your shoes.24,188 PostsLatest Activity: Jan 18, 2025
