Teeton's avatar
Teeton
Need help Duo-Therm ac thermostat/control box hook up
Ok I'm ready to hook up my Duo-Therm ac model 57915.541 with control box 3107541.009 to hunter model 42999b thermostat. I have installed a high/low fan switch also.
I read some of the hunter install links, but my wiring color coming out of the box may not be the same as the ones in the links.. I got the ac unit used off a wreck.
Ok coming out of the control box are 10 wires that go to the thermostat, also furnace and a 12 volt pos and neg.
So two wires are blue with white stripe. Those are for the heater and go to the furnace.. Right?
There's a red and a black wire that have a tags on each one of them, red wire tag saids 12V + and the black wire tag saids 12V - on it. On the control box the schematic shows them going to a solar filter indicator if used. So I guess I don't need them.. Right? They are not there to power the control box are they?
The other wires are and I don't know where they go on the thermostat hookup. Those wires are one yellow, one tan, one white, one blue, one green and one that's red with a white stripe and it has a tag that saids "to t-stat +7.5 screw" ...
One other question is dose that control box need power (110ac or 12v dc)of any kind that the furnace will still work with only the house (12v) battery is hooked up?
Thanks Ed
Having RV issues? Connect with others who have been in your shoes.24,394 PostsLatest Activity: Jun 15, 2026
