tpi
Apr 29, 2015Explorer
If in RV check draw of fridge and CO detector. Depending can be 10-20+ AH per day. Planning on using furnace?
Also the 600 watt inverter can draw 70 ish amps from battery. Doesn't look like you're planning on that from your load list.
Personally I'd plan for worst case scenarios. There's many common battery sizes in the 100 AH range.
Having RV issues? Connect with others who have been in your shoes.24,383 PostsLatest Activity: Apr 24, 2026
