icanon's avatar
icanon
Need help in buying a meter.
Let me start off by saying I'm not an electrical expert, you could say I have no clue, just + = red and - = black, hahaha .
I need a meter to check the power coming from a solar panel controller and if possible that same meter to verify my battery condition and volts. Could you suggest and point me to a meter that can do what I need. Also, on how to use this meter, which buttons, dial to use. Like I said I have no clue on these gauges, bought one a few years back and burnt it to a crisp! I don`t need the most expensive one on the market just a basic model to do the job as I will only use it a few times.
Thanks
  • First multi meter? I've been using multi meters for a little over 60 years. Buy a cheapo meter like Harbor Freight sells. Go to the library or book store and get a book on multi meters. Once you learn how to use it go buy a better quality meter. I still grab one of my cheap harbor freight meters when taking readings outside where it can be dropped and damaged. Better to frop a $6 meter than a $50 to $100 meter. Plus it isn't like these measurements are rocket science. In fact in the lab we used a Tektronics scope for most voltage measurements not a volt meter.
    BTW anyone can basically take meter readings. How to use that data and aquiring further data about the circuitry you are looking at requires a little more skill. Those pesky little electrons can trick even the smartest tech.:B That is why I recommend a book on the subject.
  • Lowes has a $80 clamp on amp meter that will measure DC amperage. They also sell a $40 one that does not.
    IT has a 40 and 400 amp DC rating, and is fairly accurate, enough for testing purposes anyway. Without cutting into the wire, you just clamp this meter over a DC wire, and it will tell you how many amps are going through it. It also works on AC lines too.
    It can measure ohms, volts, and such. Temperature too. . .
    Good luck,
    Fred.
  • I like this one:
    http://www.amazon.com/s/ref=nb_sb_ss_i_1_17?url=search-alias%3Dautomotive&field-keywords=etekcity+msr-r500&sprefix=etekcity+msr-r500%2Cautomotive%2C278
  • I have a Craftsman multimeter. It was about $30 and does a good job.
    You can often get one free at Harbor Freight, with a coupon. They do an okay job.
    Check YouTube for instructions on how to use a multimeter.
    I do like the one RJsfishin built for 12 volt use. :)
  • Harbor freight has a wide variety of multimeters from free to around 50 dollars. Take your pick, but less than 20 dollars is sufficient for 99% of your household and RV needs.
  • I have a multimeter too, but I like this one the best for 12v. I make them for just a few $s,....a meter off ebay, a pc a plastic from a elec box, a twin lead wire w/ clamps.
    You can not hurt it, just doesn't fire up on reverse polarity.
  • A basic multi-meter should do. You can get them on Amazon or at Radio shack. They come with an instruction manual. Pretty simple to operate for what you need.
Having RV issues? Connect with others who have been in your shoes.24,283 PostsLatest Activity: Jul 17, 2025
