MitchF150
Feb 15, 2020Nomad
Check the fluid level first off. No fluid, no go.. If low, fill up and it might go.
If fluid on the stick and not low, sniff it.. If it smells "burnt".. No go.. Kinda like burnt toast..
40 year old trans... Might just be done with life if it has fluid and not burnt..
Good to check the linkage, but just "hitting it" might not do much... Have to have hubby lay there and you shift thru the gears and see what the linkage does.. Go from there on what the result is.
Good luck!
Mitch
Good luck!
Mitch
Having RV issues? Connect with others who have been in your shoes.24,409 PostsLatest Activity: Aug 26, 2026
