opnspaces
Feb 15, 2020Navigator III
Are you sure that the linkage is actually moving at all on the transmission?
What happens if you start it in park and carefully press the gas pedal while still in park? Does the motorhome move in park?
Then shift into reverse and press the pedal again. Does it move in reverse?
Then shift into neutral and press the pedal again. Does it move in neutral?
Having RV issues? Connect with others who have been in your shoes.24,409 PostsLatest Activity: Aug 26, 2026
