dragr1's avatar
dragr1
Need help selecting generator
I am looking at purchasing a generator for power outage emergencies. Yes these are rare occasions, but since I switched from a motorhome to a travel trailer I miss having the convenience of just staying in the camper if the power is out.
I would like for the generator to be able to run my camper (jayco 33bhts) which has one 15k but a/c and all the normal stuff-it has 30amp service. I would also like to plug in 2 additional house refrigerators. I can of course run the RV fridge on propane if the load is too much.
It would be nice to have something relatively quiet, but since I don't plan on ever using this at a campground it's not a priority. We always camp with hookups.
I've been looking at units in the 7,000 to 10,000 watt range. Some have rv plugs directly on the unit and others do not-I assume there is an adapter if they do not?
These are some of the units I have looked at:
http://www.sears.com/duromax-durostar-10000w-portable-gas-electric-start-generator/p-SPM7298198902?prdNo=27
http://www.planetgenerators.com/powermate-pm0497000-04-review/
http://www.planetgenerators.com/duromax-xp10000e-review/
http://www.homedepot.com/p/Champion-Power-Equipment-7-500-9-500-Watt-Electric-Start-Gasoline-Powered-Portable-Generator-with-50-Amp-and-RV-Outlet-CARB-41534/203649714?N=5yc1vZbx9nZ1z0z74f#specifications
http://www.homedepot.com/p/PowerStroke-6800-Watt-Generator-Honda-GX390-Electric-Start-PS907000A/204401587?N=5yc1vZbx9nZ1z0z74f#specifications
http://www.northerntool.com/shop/tools/product_200614588_200614588
Thanks for any help or advice!
  • Starting to take a look at the Generac's. Anyone have any info on them?
  • I just purchased a generac 8500 very nice buy it's a little loud. Wanted something to run my we'll. if you take your voltage and are able to get you amp draw that will tell you your wattage . (Amps x voltage) also if it has a motor you want to check the amp draw on start up. My we'll runs around 9 amps but on start up it jumps to 26 amps.
Having RV issues? Connect with others who have been in your shoes.24,190 PostsLatest Activity: Jan 19, 2025
