Golden_HVAC
May 31, 2015Explorer
Suppco SPP4E is rated at 120 volts and anything under 3 tons.
Also you should be monitoring your input voltage. If you are less than 108 volts, watch it very closely, and shut it off if below 105 volts.
I plug in a voltage booster if I am below 113 volts. Many times if it is a state park, or only 30 amp services, you will need a voltage booster. But places with 50 amp wiring is much larger wire, rated at 150 amps or more, and not as likely to have a bad voltage drop.
Good luck!
Fred.
Good luck!
Fred.
Having RV issues? Connect with others who have been in your shoes.24,390 PostsLatest Activity: Jun 05, 2026
