RickLight
Sep 01, 2019Explorer III
Is the dimmer like this?
https://www.amazon.com/dp/B07D2CPJ3S
If that's at all right you should be in good shape.
Do you have 4 wires? 2 from the source, 2 from the light.
Does your dimmer have 3 wires or 4. If 4 then it's just a matter of sorting line and load, positive and negative. If you have 3 wires then one will go to both negatives and all join together. The others to positive and load.
If you only have 2 wires then you may need a different dimmer.
Having RV issues? Connect with others who have been in your shoes.24,409 PostsLatest Activity: Aug 29, 2026
