RickLight
Sep 03, 2019Explorer III
No, not all whites are ground. In fact 12VDC systems don't have a separate ground like household 120VAC systems. Negative is usually the chassis that works sorta like a ground. If you have a return from the lighting then you don't need a new wire.
Color codes also vary widely. You'll find products from outside the USA often have black and white reversed from our normal black=negative. Sometimes you'll see red instead of white, or yellow, or, or, or they're just all the same color!!
This guy does a great overview of dimmers for RVs.
https://youtu.be/wv7h8jDPZ8g
Having RV issues? Connect with others who have been in your shoes.24,409 PostsLatest Activity: Aug 29, 2026
