OnaQuest
Oct 23, 2013Explorer
I suspect that your current disconnect switch is wired to disconnect the battery from the system, but not disconnect the converter. You need to devise some way of disconnecting the 120vac from the converter input when that 120vac is being supplied by the inverter. There is probably a circuit breaker that you can trip.
