mena661
Oct 23, 2013Explorer
NWLady wrote:This is how I did it although I'm certain the angry at anything but a sub-panel crowd will show up to poo poo on my setup. Regardless, it works and doesn't need a contractor (to replace the walls that you'll have to tear down to run new wires to your sub panel...yes that's what you'd HAVE to do in my rig to use a sub panel...even my old rig would've required this but no one elses does apparently) nor an electrician to implement.
I know there are different ways to accomplish this but at present I am favoring the installing a 30 amp receptacle from the inverter on the outside of the van and plugging the shore power plug into this when I want to run 120v off batteries.
