MEXICOWANDERER
Sep 29, 2020Explorer
Nope
There would be even more series resistance. Try a 1K 5 ohm resistor in the dinette power in to negative circuit. That problem would disapprear. It would draw down bleed threshold. I tried to not write the encyclopedia brittanica on this issue. The resistor I mentioned would exhibit a Delta T dissipation maximum of 12 watts. But minus the load of the LED lamp. Shoot, if you want no heat at all use a thirty watt resistor. Equal to 2.5 amps capacity. I do not do guesswork :)
Having RV issues? Connect with others who have been in your shoes.24,380 PostsLatest Activity: Apr 15, 2026
