MEXICOWANDERER
Sep 29, 2020Explorer
30 watts. 300 ohm ADJUSTABLE RESISTOR.
Keep expanding the distance with the slide control. And limit the current to 1/10th amp.
At your given specs, this resistor may heat to .01 BTU
For you, start wide and slide the band until the problem resolves itself then clamp the band. Impossible to go wrong.
Having RV issues? Connect with others who have been in your shoes.24,380 PostsLatest Activity: Apr 15, 2026
