spacebetty's avatar
spacebetty
Need help with my sketchy battery cable situation
I was about to replace my 2 12v marine batteries with 2 6v deep cycles, when I realized the cable situation seems strange and possibly scary. But I don't know much about battery cables, so maybe it's fine. Here is a photo of the cables in question:
The red cable is obviously +, and the white one with black on the end is -. The first sketchy thing is how the ends of the cables are all taped up and homemade - WTF? How do I know if they're an appropriate size? Also, there is a thin black ground wire coming from the taped up part of the + cable, which is bolted to the trailer frame. Why would the + cable be grounded? Isn't that what the - cable is for?!
The 2 cables that were used to connect the 12v batteries in parallel are also of this taped-up homemade variety. I was going to use one of them to connect the 6v in series, but now am unsure whether I should use ANY of these cables at all. Wiring in new cables seems really daunting because I can't see an obvious way to access where they run up into the bottom of the trailer.
Blargh! Any thoughts?
Having RV issues? Connect with others who have been in your shoes.24,341 PostsLatest Activity: Dec 04, 2025
