time2roll
Sep 05, 2014Nomad
Cut all that tape and junk off. Get some crimp butt splices with heat shrink, heat gun, marine tinned wire of same gauge and of proper colors, closed lug ring terminals that match both the battery stud and wire, weather tight fuse holder for the positive side, heat shrink tube as needed in proper colors, quality wire crimper.... and get busy :B
And if you ever charge from a generator replace the entire battery loop with #4 marine cable and update the converter as needed.
Now you are sorry you asked ;)
Having RV issues? Connect with others who have been in your shoes.24,363 PostsLatest Activity: Mar 03, 2026
