time2roll
Sep 05, 2014Nomad
spacebetty wrote:No stay with what you have is fine. The fuse would be for a short circuit. The battery could easily melt that wire and cause a fire. If no fuse currently I assume it is wrapped under all that tape or the prior owner just removed it.
I don't use a generator, but I do use a smart charger plugged into house power. Do you think I need a larger gauge wire for that? Also, just curious, what is the purpose of the fuse on the positive cable?
Having RV issues? Connect with others who have been in your shoes.24,362 PostsLatest Activity: Mar 02, 2026
