wnjj
Sep 05, 2014Explorer II
2oldman wrote:spacebetty wrote:Only fans and pumps care about 12v polarity.
when the 2 12v batteries were hooked up, they worked with the red one on the positive terminal and the black/white one on the negative. Could they have still worked this way if what you say is true?
The polarity inside the trailer may be just fine anyway. I'd bet there are 2 wires running to each device. The weird thing is a positive ground. Many years ago some cars used to do that.
In the end if the frame isn't used for current carrying it probably doesn't even matter. The frame is only underneath and not near the loads which are mounted in wood.
It would matter if a vehicle charging wire was hooked up and then you'd need move the frame connection to the negative side and rewire anything inside the trailer that is electrically connected to the frame (if there is anything).
Having RV issues? Connect with others who have been in your shoes.24,362 PostsLatest Activity: Mar 02, 2026
