johntank
Sep 05, 2014Explorer
there is a thin black ground wire coming from the taped up part of the + cable, which is bolted to the trailer frame. Why would the + cable be grounded?
Seems to me that someone has set trailer up to work on a positive grounding system. It will be a job to trace the wires all the way back to the converter or fuse panel to see what is going on with the wiring and maybe why you have a wire from the positive side of battery to frame.
Having RV issues? Connect with others who have been in your shoes.24,362 PostsLatest Activity: Mar 02, 2026
