logsfam's avatar
logsfam
Need help with propane issue!
My propane will work fine to 6 to15 hours straight then all of a sudden the gas flow will become very low. Sometime after turning all appliances off for a little while it will start working again and then again sometime I have to shut off the gas supply and disconnect the bottle then reconnect and turn back on before it will work again. While disconnecting the gas line it is under pressure and the gas indicator is still green so I am assuming the problem is not at the gas valve in the bottle.
This led me to believe I was experiencing a freeze up at the regulator or experiencing a regulator malfunction. I have since that time replaced the regulator with a high capacity dual auto change regulator. When I changed this out I discovered a 16” low pressure line that leads from the regulator to the copper tubbing which distributes the gas was leaching oil and getting soft. This line was replaced as well.
Everything appears to be working fine for an extended time then all of sudden the gas flow will slow way down again. Has anyone experienced anything like this or have any ideas what the problem may be?
Having RV issues? Connect with others who have been in your shoes.24,332 PostsLatest Activity: Nov 05, 2025
