MEXICOWANDERER
Aug 21, 2015Explorer
Power goes through the wire that will make a test light glow with the igntion switch turned on. The test light will play possum when the Fuel Pump fuse is pulled. The pump most likely has a relay so underdash work may not be fruitful.
Having RV issues? Connect with others who have been in your shoes.24,398 PostsLatest Activity: Jul 02, 2026
